Flashing Bios (Neo2 Plat). . Please Help!!
jnick
I have a MSI K8N Neo2 Platinum running the BIOS that came with it. Today I finally picked up an external FDD so I can flash it.
So I read the online instructions to do it on MSI site and it seemed easy peasy as I've flashed BIOSes before (a while back though). So I made my MS DOS bootable Disk then put the BIOS files on the disk.
I decided for giggles to read the instructions packaged with the BIOS files. They are COMPLETELY different from the one's on MSI's site, and different from how I did it with my Abit. not to mention, they have 2 different methods on one instruction sheet. So now I'm left with 3 ways to flashing the BIOS and have no clue which to use.
The first method is explaining to make a boot disk, then task another FD and put the bios files on it, boot from the disk, execute the files and viola.
Another is saying "DON'T USE A FLOPPY DISK!!!". Instead, they want me to put the files in a folder on my C drive and extract it from there.
Finally, the last is entitled "Flashing the BIOS for Non-FAT file system". This method is EXTREMELY different from the other two and talks about using ONLY a 98/ME boot disk (not as MS DOS one) and you have to use a RAMDRIVE and copy files from here to there, etc.
I was initially using the first method as posted on MSI site. The other two showed up in the instructions with the 1.B bios. Which do I use? Is it safe using the first "Normal" method.
PS - I'm running XP which is why I yielded when I saw "Non-FAT" files system.
Any help is GREATLY appreciated.
Cheers.
same, the winflash utility should be fine, ive used it multiple times for mine...
(by the way, the new bios's BLOW, they caused rediculous instabilitys on my system...)
I heard the MSI Live Update utility screws your system with the newer bios . . .?
I have this same board. I use the MSI Live update utility with the floppy and simply followed the instructions. No problems. I flashed my bios and upgraded my drivers. Simple to use.
