Flashing BBATI 9600xt
jackbauer
Just wondering if anyone has done this or not. i am running atitool on it now and just wanted to know if i could flash the bios to a 9800 or something better that the stock 500/300 settings
On my 9600np I had to use the omega drivers to even be able to oc it. From there I let ati tool decide the max oc, then upped it a little. Hope that helps better than the other waste of a post.
Therers nothing to flash a 9600XT to; the 9600XT is the fastest of its family. You cant flash it to a 9800 because they are two totally different architectures, it has 8 pipes vs the 4 of the 9600, it has a 256bit memory interface vs the 128bit of the 9600. They're alot more than higher clocked 9600's.
