JOKER_JOKER
- Nov 2, 2005
I would like to create an interactive web application which allows a user to create a master timeline, and they can add intermittent points on the timeline. In addition they can click on any of those points and create a subtimeline (and add intermittent points on this line). Also, they can create lists for each of those points. Finally, they should be able to save their timeline to a database, load it, and edit it. I want this inside of a website, what would be the best technology to get this task done? The only two I really know of is Flash and Java, but if there is something easier I would like to know your opinions. What would you use? Thanks.
