- Mar 26, 2008
I experienced a really weird issue the other day when shooting with my remote flash setup. Wondering if you guys might have any solutions for this.
On my D90 the max flash sync speed is supposed to be 1/200”. I have successfully gotten images to turn out as high as 1/250” by attaching my SB900 by pc-cable to the hot-shoe, which unlocks the shutter speed. By using that method, anything much over 1/250” causes some weird black bars to appear in the photo: something to do with the movement of the shutter leafs and the way the light from flash falls across the subject.
A few days ago I decided to take some product-shots with my new macro-light-box (large cardboard box w/ holes cut in it, holes covered w/ white shower curtain or tracing paper, and lots of duct-tape). I set up two flashes (SB900 & SB600) on stands on either side of the box, each hooked to a pocket wizard, and a third PW on my camera to trigger flashes.
I started with the flashes set to about 1/8 power and the camera shutter at a modest 1/180”. But to my shock and horror, about one out of every two or three shots was having those black bars, like I was exceeding the acceptable sync speed! I tried turning down the shutter speed as low as 1/100”, and also checked my camera’s flash-settings to make sure I wasn’t using rear-sync or any other unusual settings (guessing I missed something); but randomly one out of every few shots was still getting the black-bars error.
After this, I also tried shooting some with just ambient light to make sure something wasn’t just completely messed up with my shutter. With ambient light, out of a couple dozen shots, none of them had the black bars; so I don’t think the shutter is doing this on a regular basis – just something wrong in my flash setup.
Cliffs: When using remote-flashes and pocket-wizards, my camera-shutter speed is refusing to sync properly, even at speeds as slow as 1/100”. It happens intermittently, not in every shot.
Any idea what could cause this? Is there something wrong with my camera’s shutter? A setting on the flashes or PW’s that needs to change? Any help would be appreciated – I would hate to have a really important shot ruined at some point because of a sync error.
