Flash Gateway mobo with Intel BIOS?
fishdiggy
I saw someone asked this question a while back, but never got a good response. Has anyone tried to flash a Gateway board with an Intel BIOS? I've read (from multiple places) that the Intel flash utility won't allow you to do it, since the two boards have different BIOS strings, but what about using a generic AMI flash utility?
I'm looking into buying a retail D875PBZ Intel board, but their availability right now is sketchy, and they're also quite expensive. This board is a lot cheaper, and appears to be feature identical, except for the Gateway BIOS. Thanks for the input.
Why do you want to reflash it? Gateway typically leaves all the same features in the BIOS as Intel does, they just add their logo. Which on my last Gateway, was able to be turned off by a BIOS setting.
I'm mainly concerned that the RAM timing adjustments and the "Burn-In" mode won't be in the Gateway BIOS (although I can't find any information to confirm this), since they tend to remove things like that to keep novice users from meddling where they shouldn't.
I used to do it with P1 era boards. I haven't tried in a while, though.
/edit: May I ask why you want the Intel board? Why not just go to newegg and pick up an Abit or Asus. It should be around that price.
/edit2: just checked the price. maybe not :)
