MelonSplitter
- Aug 6, 2006
Why does my new SanDisk Ultra 3.0 starts transferring at about 60mbps then after 10 seconds and 1/4 of the way it slows to 25 mbps?
Since active trim is not supported on usb flash yes. You need to erase the whole thing - because to get your speed back you need to write to a sector that has no data in it already.So to remedy this I should format the flash drive before each time I use it?
Formatted to NTFS and problem is the same. Starts off at about 60mbps and after about 1/4 of the way it slows down to 24 until complete. Very annoying. Clean install of Win 10 Pro with all updatesJust star with a clean partition and test.
