Jul 23, 2004 #1 R RoyLuv Limp Gawd Joined Jul 20, 2004 Messages 361 I have a 9800pro and have learned that I may be able to flash it to an XT. How can I tell this card is flashable to a XT? And what BIOS update would one use? Just the latest XT BIOS or is there specific versions I would have to look for?
Jul 23, 2004 #2 G Glyndur Gawd Joined Feb 22, 2003 Messages 882 This is a really good guide outlining the cards that can be modded to XT's. Basically if you have a R360 core then in can be done. http://www.rojakpot.com/default.aspx?location=3&var1=92&var2=0
Jul 23, 2004 #3 T TechHead 2[H]4U Joined Oct 12, 2001 Messages 3,870 ^^Excellent link. Lotsa info in there.
Jul 23, 2004 #4 C Circuitbreaker8 Supreme [H]ardness Joined Jul 22, 2004 Messages 5,078 Is it worth it if you have the R350 core? My card does 470/380 max...i wanna push a little more hehe.
