Just posting information on the lastest version of my flamethrower mod.
I fixed the sound looping issue from earlier versions. Also changed it so the flames should shoot out as a cone.
Unfortunately will be a week before I can try out the mod myself so I hope someone can tell me how it works out and take some pictures (if you need a place to host images ImageShack works well). So if there is any issues just tell me and I should be able to fix them but changes are minor enough I doubt it won't work fine.
http://www.geocities.com/cryect/flamethrower.html
