Fixing broken temp probe?
jm8881
Where can I buy a new temp probe to fix this?
I broke the little sucker soon after hooking it up and removing it from the hsf on my vid card.
The one on the right looked just like the one on the left.
Thanks.
i have the same problem, but i dont use it the front panel temp thingy sooo i ripped that metal thingy off. if you get any answers "holler" at me :p
