fixing a loose side panel
camelass
On my Lian-Li PC-7B the side panel that doesn't have the window is a bit loose at the front of the case. If you gently push in on the panel theres some give. I was just wondering what the best way would be in trying to fix this?
go to home depot and put some weather stripping, on either the case or side panel. You dont have to have place a long strip, just enough pieces to where it prevents the rattling. You dont even have to use weather stripping. Just some cardboard, or pieces of tape/napkins layered over each other.
I had the same problem with that case too man , got some one sided sticky felt striping and put on the inside, fixxed the problem for me.
