- Feb 5, 2025
So, I finally decided to play with my grandma's old PC, a Dell Inspiron 570 (Athlon iiX2) and install Linux and give it the old system, new life treatment.
Right now, I have it in good condition, except for that the system fan header is broken, multiple fans tested, none of them spin when plugged in.
This isn't an issue in and of itself, as I ran a fan splitter from the CPU fan header to get my exhaust fan back. My problem now is that the stupid fan error (that cannot be turned off in bios) delays the system startup by like 30-45 seconds, (I know because when the fan header worked, it would be a lot quicker, and I'm assuming it diagnoses this issue every power on).
Do any of you guys have any solutions to maybe trick the header into thinking there is a working fan, if you do, please share, and thank you in advance for your help!
