Fix for skipping/repeating audio in Doom3
Conman
Doom3 was nearly unplayable for me with constant repeating/stuttering of the audio which would cause the frame rate to drop like a rock. That was until a game reviewer found a solution.Link to review
Edited August 8th: After some more time researching my sound problem, I stumbled across a solution that gets rid of the stuttering completely. All you have to do is right click your hard drive, click properties, go to polices, and turn off write caching. The sound is smooth and doesn't skip at all. Hope that helps other people as well.
After making the change audio works perfectly and no more frame chugging. :)
