Fix a scratch in black anodized case
Ensign.Fodder
As we all have (master modders excluded) probably done at some point or another I was not paying attention when disassembling my case and set a piece down on something that had a bit of an edge (staple pushed through chair from frame) and scratched the anodized surface off the aluminum base. It was a inexpensive case (sig) and the anodizing was not very thick. All that being said what, if anything can I do to fix. I have tried the Sharpie method but it did not cover enough or blend well. I will have images up shortly but the scratch is about 1 CM long and 1 MM wide.
Thanks!
Marker from an art set maybe? Pick a color that matches! Sure it wont be permenant and water proof, but dont rub it or wash it...
In another forum I saw someone suggest model paint since it might bond to metal and they might have a good color match.
Heres my reply from another thread. Like I was saying just lightly sand to match sheen. As far as primer touch up, if you want the same effect just use a primer, either in paint on or spray on, however for the spray on, just shoot a little in a bottle cap and paint on as I mentioned in this thread.
http://www.hardforum.com/showthread.php?t=1363608
Go to home depot and ask for aluminum paint.
Interesting
From Ace website
ALUMINUM PAINT
High-quality aluminum paint is aluminum blended with a resin base. It works equally well on almost any surface and may be brushed or sprayed. Colors become more intense with age.
Aluminum paint can be used on all interior and exterior metal or wood surfaces, or applied to metal flashing, gutters, downspouts, tools, tool sheds, patio furniture, pipes, mailboxes, fences, etc.
Do not apply aluminum paint during freezing temperatures; paint should dry at least overnight before re-coating.
