Five questions about building a game pc.
Zan
What will you be doing with this PC? gaming
What's your budget? 750+taxes
What exact parts do you need for that budget? everything except monitor and speakers
If reusing any parts, what parts will you be reusing? monitor and speakers
Will you be overclocking? never
What size monitor do you have and/or plan to have? 25" now but 28" soon
When do you plan on building/buying the PC? i need it built by labor day
What features do you need in a motherboard? ability to add second video card down the road
Do you already have a legit and reusable/transferable OS key/license? i do not need an os
I plan to keep XP Pro, so my system will be limited to 4 gig of ram.
I don't require all graphics options turned on to enjoy a game, but I'm hoping this system will be fine for bioware's new MMO which will probably be released sometime in 2-3 years.
This would be a game system, with a focus on first person shooters and online role playing games.
My total budget is around 750-800 plus taxes, etc
Here are my questions:
1. I'm now reading that it might be better to wait for the i3 or i5 and pass on the i7. Why is that?
2. If I built a system around a core 2 quad, would it be unrealistic to expect decent gaming performance for at least 24-36 months providing I was willing to upgrade the video card in a couple of years?
3. I expect to buy a 200 series geforce, but am not sure which one to get. Is there a big difference between a 260 and 275, or should I buy the card with the most ram?
4. My chosen power supply is a Corsair 750w that is 80plus certified. That's a pretty safe choice isn't it?
5. I'd prefer to stick with my dependable XP Pro. Is there a real need for me to switch to Vista or Windows 7?
By far my biggest decision is on what type of cpu to get. I am partial to Intel, so that leaves me three choices, quad, i7, or wait for the i3 or i5. I'm really not in a position to wait much longer, but if buying a quad or i7 is a bad choice then I suppose I could. I'd prefer to get a quad, since that's closer to my price range, but I'd hope to keep the system for at least two years and preferably three. Would buying a new video card in two years be enough to extend the life of my system by a year? If I felt there was a good chance of that then I'd probably just buy a quad.
Thank you.
1. If you don't need something right now, its always good to wait for new products. i7 products are still expensive relative to your budget and needs. i5/3 may provide the performance you need at a better price than current PhenomII options. i7 only really improves gaming over Core2/PhenomII when running 2+ vidcards, which is only needed for 2560x1600 resolutions, IMO. With 1920x1200, I'd stick to a single vidcard (dual GPU).
2. No. Core2Quads are still very good CPUs, though they don't offer the most bang for buck. PhenomII's offer the most bang for buck right now, considering your budget and needs.
3. VRAM helps with details, so keep that in mind as well as your resolution. The best bang for buck vidcard right now is the HD4890, which tends to perform on par with or better than the GTX275, and is priced cheaper.
4. Sure, but not needed for a single card setup -- its overkill. For a multi-card setup, it depends on the vidcards.
5. Not unless things you want to run won't run in XP. BTW, 7 has an XP mode VM. ;)
Buying an i7 isn't a bad choice in general, just bad for your budget. The PhII X4's perform up to par with the Core2Quads, and are cheaper, so those would be your best bet. If you don't plan on upgrading your CPU for a while, then I guess a Core2Quad is fine, if you can find a good deal. LGA775 has reached EOL, so there will be no new chips for it any time soon or in the future, IIRC.
So no new chips or boards are being manufactured for the core 2 quad?
Eaglelake is the last chipset for LGA775 (G4x/Q4x/P4x/X4x). I don't think there are any more Core2's in the pipeline, duo nor quad.
There may be low powered overpriced gimmick CPUs. i3 is basically C2D/C2Q.
