Thanks everyone for your help in http://hardforum.com/showthread.php?t=1874100&highlight=. Aside from order some different fans with PWM, I have all of the components. There are just two things I could use some help with. There is very little room between the SDD and the PSU that the SATA power and data cables have to make a 90 degree bend. It's not so bad that I think I'm instantly breaking the wires, but i'd rather do something about than leave it as-is. Does anyone have any recommendations for an adapter or cable to make this 90 degree bend? I've seen http://www.amazon.com/dp/B00B4KL8Z6/ on Amazon which looks interesting, but I am always leery when an product has so few reviews.
I have a similar issue with the graphics card I chose. I don't have an issue with the length of the card, I have an issue with the height. The 6-pin PCI-E power connector is very close to the top of the case that it has to make a similar 90 degree bend. The problem here is that I plan to put my TV on top of this case and the weight might be enough to depress the top of the case and could bend this cable more than I want to which can also put stress on the video card. Unfortunately I can't seem to find a cable/adapter to help with this problem. I'll keep searching.
