I had to mod an Antec Oveture to fit an Enermax 535W PSU that it clearly wasn't designed for. It works fine, except for a bit of wiring mess. Only problem is there was no way I could get the screw holes in the overture case to line up with the holes on the PSU.
With the way the PSU is stuck in a cramped spot on the case I seriously doubt I'd be able to measure a spot to drill new holes for the PSU.
Any one have a good recommendation on getting the PSU locked into the case?
