Fitting a H70 in a midtower
Krieger91
I have a Lancool Dragon Lord PC-K62 case, it's a mid tower and I am really not sure if the Corsair H70 would be able to fit into there, does anyone have experience with fitting this into a mid tower?
Haven't done a build with that case, but looking at the company web site, I can see they have pass throughs for water cooling below the rear 120mm fan. So to answer your question you should be able to, the rad for the H70 must be mounted to the exterior of the rear 120mm fan, on the back of the case, and leave the fan on the inside.
I would just email the company to make sure 100% they will know right off the bat, or just call them.
goodluck
goodluck
Oh yeah, I just saw those when I was looking, I have another question now lol. Is it possible to disconnect the hoses from the H70?
at that point, you might as well go custom. because most people have a PITA of a time to get the hose back and fully filled with water.
Here is a pic of the H50 in mine. I thought the H70 had shorter hoses so it should fit better.
The H70 is not that hard to fit. I have put two in Rosewill Blackbones, and two in Antec 300s. It should fit in any standard midtower
The H50 and H70 are designed to be easy to install in nearly any case with a rear 120mm fan. You should be ok
