fitting a baybus behind the door....
finally now that i have the money to buy a good one, which baybus (preferably black/silver with blue lights) will fit behind this case's door?
oh, and got any mods in mind that i could do? all of the ugly ass tri-LED fans are replaced by 3 antec blue LEDs , a smartfanI and a smartfanII(no blowholes ive already reached my max OC)
i already have a window applique on it that says "AMD Whoop-Ass Inside!"
if you get a baybus thats just a lil too big, you can always slide it back a lil bit but if u want to keep it nice and pretty, get shorter knobs
heres a mod that i did that you may wanna do
i wired a red LED from my powersupply with a resistor to the bottom of my case thru a hole from the inside it shines outward so when its dark, it seems to glow beneath the case... however, some cases may be to low to show enough light so i just made it higher by taking empty rolls of scotch tape and using it as riser under the case
its looks madd hott with that mod and it doesnt take a long time to do either you can secure the led with hot glue, which is what i did
