Hi guys
first post on this forum, first watercool job
I've been doing a lot of reading on the subject recently and i've got an idea of what i'd like to do and a list of parts to do it with, but i'd like some advice on the matter
Here are some of the system specs (none of which are final)
Processor: INTEL CORE2 QUAD Q6600 2.4GHZ
Mobo: ABIT AW9D-MAX LGA775 I975X P4/C2D ATX BOARD
GfxCard: XFX 8800 GTX XXX
Ram: OCZ2G8002GK PC2-6400 (4x1GB)
Case: SILVERSTONE TJ07
So thats the core of the machine that I intend to watercool.
I've been looking at various Kits, most i dont like the look of visually, but i am quite fond of the Evercool 202
pic 1
pic 2
read a review of it here
From what i can tell (the 5 or so reviews i've read on it) it seems quit good. Not "hardcore" in a DIY sense i guess but it seems to deliver what i'd need, but i'd be interested in hearing people's experiences with this setup.
The thing that i like the most about it is that its compact and fits away nicely out of sight, but also gives you a front plate with easy access for top ups/filling and temp info/"control".
However i have been thinking about making some mods to it, to squeeze out every last bit of cooling from it.
For starters not using the generic heat paste that it comes with it but using some Thermaltake paste, which supposedly can help shave off a degree or so.
Replacing the water block for the CPU and GPU.
The CPU with a SwiftTech Apogee
pic 3
For the GPU i was originally thinking of getting a Dangerden GTX waterblock, but i was told they had had some bad/or mixed reviews and that i should go for a EK-FC8800 GTX - Acetal
pic 4
but i'm not sure..so i need some advice there.
I was also considering either replacing the included external Radiator with a Black Ice extreme 2 Rad, which would go down the bottom on its side next to the PSU.
pic 5
so the loop could look like this:
Evercool>GPU>external rad(included)>CPU>Evercool
This is because i am thinking the external rad would be more efficient at cooling the water than the internal. (i should point out that when i say internal i mean in the drive bay, and external i mean still within the case but in its own section of the case, either at the back or down at the bottom)
According to reviews it seem to be able to cool quite well with its included rad's But because it will be a quad core (and i may try to OC it just a fraction, nothing insane but no reason why not if the wc can handle it) i thought it might need some better cooling. Which is where the Black Ice would come in.
in which case the loop could look like
Evercool>GPU>Black ice>CPU>Evercool
or if i got some more tubing i could keep the original external rad in the loop as well
Evercool>GPU>black ice>CPU>original rad>Evercool..or some such thing
But i'm not sure if this would even have an effect...
A few more Questions.
When adding/removing blocks from your loops, after its all set up once and running, how do you go about doing this without taking of a tube and liquid spurting everywhere? or do you just take it all out and drain it and start again. Its just i get the impression from reading some people's posts thet you can make additions to the loop without dismounting and rebuilding..just curious, not planning on making any changes once its set up.
I'm trying to decide between
PrimoChill PC ICE Non-Conductive Water Cooling Fluid - UV
and
MCT-5 Non-Conductive Solution (i thought i found an MCT-40 but i can't find it anymore
If the promochill is as effective at being non conductive i'd get it, because it looks better and is UV reactive. but its the (relative) safety of my system that i'm more concerned about.
Thanks for your time and help
pic 1
pic 2
pic 3
pic 4
pic 5
and
