Hey all - I'm finally going to WC my rig after thinking about actually doing it for years Here are the important specs of the build:
Case: Lian-Li V1200B
GPU: Core i7 920
GPU: EVGA 260GTX (may very well be upgraded to a 560 Ti)
CPU WB: XSPC Rasa Link
GPU WB: XSPC Rasa GPU Link
Resevoir: XSPC dual 5.25" Rs with DDC mount Link
Pump: Swiftech MCP355 Link
Rad: XSPC Rx120 Link
Tubing: Tygon 3/8" ID 5/8" OD clear tubing Link
Fittings: I am planning on using Bitspower matte black fittings when I decide what fittings i will need.
Fans: Yate Loon low speed fans, these are be the best and quietest last I heard, but am open to changes. Must be quiet!
I think those are the main components, I don't think I missed anything. I am planning on ordering everything from Sidewinder other than the pump, that will come from Newegg. (Using the commissioned links of course!)
I am planning on placing the radiator in front of my V1200 where there is already a 120mm fan. I could move the HDD cages because I hope to be building a server to get rid of my 2 storage drives and placing my SDD under my optical drive leaving my with plenty of room in the bottom where I could possibly mount a dual 120mm sucking air from under the case since it will most likely be sitting on my desk. I will try to get a MSPaint rendering up in a few minutes.
here are the renderings:
One rad with one pump:
Two rads with two pumps:
GPU: Core i7 920
