First watercooling build...
porky1011
Hey guys , sorry I double posted , never realised I posted in the wrong section , can an admin please move original thread , thanks:) original :
http://www.hardforum.com/showthread.php?t=1307181
Hey guys , I need to cool :
2x9800GTX , 1x 780I NB , 1x Q6600
heres what iv put together :
http://www.overclock.net/attachment...11065261-thanks-help-about-order-untitled.jpg
now im kinda new to water cooling , soo i just want to make sure everything in their is correct....
I have a cosmos S case , soo i can mount the 360rad ontop , and the 240 rad at the back........
would a single 360 rad be enuff to cool all the components? , or is it a wise choice to get 2 radiators?
thanks for any help
peace
porky-
Those rads suck and are overpriced.
I'd get a 3.120 MCR radiator, and another single 120mm MCR radiator... Or a single PA 120.3 triple rad.
The rest is alright though. I'd get a Dtek Fuzion over your block... But that's about it.
looks fine to me apart from you put the wrong size compression fittings in your cart to go with the tubing...
and do what Arcy said and get the Swiftech rads theyre much better.
oops....
thanks for letting me know , still havent ordered....
will the pa 120.3 tripple rad fit in my Cosmos S case at the top???
will a single rad be enuff?? , im gonna volt mod my gpu's and oc them a lot!
thanks
the pa 120.3 should fit at the top, and but i dont think it would be enough rad for OC'ing those components much, if your gonna have more then one rad its probably better to go with the MCR 120x3 on the top of the cosmos and a mcr 120x2 on a rad box in the back or mounted inside the 5 1/2 bays i the front. that should give you enough rad to dissapate the heat for your needs
it would be close but i think it could fit, a 120x2 isnt that much more exp then a 120x1 though
um , one more thing , I actually dont wana get $300 worth of gpu blocks for my 9800's , cos then when i want to upgrade im gonna be sitting with useless blocks , are their any blocks that will fir on all gpu's??
and sli capable?
