Crankmonkey
- Oct 21, 2004
Ok so ive had my computer for a few months but its gotten to the point where its just too damn loud
So water comes to the rescue in my mind. Now Ive recently picked up a new case a Rocketfish because for one it was $70 and a rebadged Lian Li ^^ it should look like something like 96redformulas case here : http://www.hardforum.com/showpost.php?p=1032776081&postcount=513
Next up are the items Im going to be cooling:
CPU, NB, and GPU and anything else that you guys think I should hit up in the loop.
More specifically the items that are going to be cooled or needs fitting are:
780i EVGA board... the CPU; a q9450, the NB on the 780i , and 2 8800GTs. Im thinking of using a http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=210 for the CPU, http://www.swiftnets.com/products/mcw60-R.asp for the 2 8800GT 's. Now I'm at a loss as to what to use for my NB block and what kind of radiator and pump to go for.
Thanks
Thanks
