Bit of background.
I have spent most of my computer building years saying I would never do this because of the fear of ruining the computer. Last week I finally got the itch to do this because it was something I had never done before and the modding bug is going around.
I spent a good solid week going over and over parts and finally ended up with.
http://starshipvonbraun.com/ss/wc1final.jpg
http://starshipvonbraun.com/ss/wc2final.jpg
Everything was purchased from sidewinder and crazypc.
This is the basic design of what I am going to do. Please disregard my extremely poor paint skills. Also, there will be some other case mods that are explained in the picture.
*note, I just noticed I didn't draw a line for the fill tube that will go from the top of the res to the top of the case or possibly the front.
I put two paths on here, both in yellow. There are two paths I came up with, I am not sure which is best. the tubes from the radiator will run down both sides of the PSU.
This is all for now. I get some photo of the parts up here later when I get home and get them.
