This will be my very first attempt at setting a water cooled rig! I was looking into the All in one option made by thermaltake called Kandalf Full Tower
Case Series-
Black w/ 25cm Fan Side Panel Window. Right now my setup is on air cooling and it gets very hot due to the fact that my case has awful airflow.
My current setup includes:
Windows Vista Ultimate 32-bit
AMD Athlon 64 X2 3800+ 2Ghz
ASUS A8n-SLI motherboard
EVGA Nvidia 7950GX2
Creative Soundblaster X-Fi Elite Pro
Western Digital 74GB Raptor
WD 250 GB HDD
an old Quantum 30GB HDD
Plextor 760A DVD Burner
LG DVD Reader
Mitsumi 12in one Media card reader/floppy
Aero Cool 620 watt modular power supply
2gb Corsair DDR-400mhz
Now I am interested in upgrading my components to
- ASUS P5E3 Deluxe/WiFi-AP LGA 775 Intel X38 ATX Intel Motherboard
- Intel Core 2 Quad Q9300 Yorkfield 2.5GHz LGA 775 95W Quad-Core Processor
- Patriot Extreme Performance 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit
all other components will be reused if possible!
I know that the Kandalf should be able to handle coolng the CPU, but i'm not sure if it will be able to handle cooling the 7950GX2 and the CPU.
My questions are:
1. I am also unsure as to weather I should bother buying a full GPU water block specifically for the 7950GX2 or if I should just get 2 GPU blocks and ram heat sinks.
2. Do you guys think it is cost effective to properly cool the 7950GX2 or would it be more economical to go out and buy a 9800GTX and a new Block for the entire card?
3. Are the stock Kandalf case components worth it or should I build my own rig?
4. Is DDR-3 Worth the extra cost?
5. Will I need a more powerful Power Supply?
6. What type of coolant should I use? What CPU/GPU Blocks do you recomend?
7. Are copper blocks best? (Brass/Bronze/Copper/Aluminum)
I know I am asking a lot of questions but I am new at this and I just want to make sure I make the right decisions.
-Thank you all for your input!
Case Series-
EVGA Nvidia 7950GX2
WD 250 GB HDD
LG DVD Reader
My questions are:
