InvisiBill
- Jan 2, 2003
From http://hardware.slashdot.org/story/09/09/24/1915219/First-Ever-USB-30-Hard-Drive...
http://news.techworld.com/storage/3202573/freecom-outs-first-ever-usb-30-hard-drive/
I'm very glad to see it reasonably priced. I don't think it should cost that much more to manufacture, as it's probably not much more than changing a chip on the interface board.
This is great too. Currently, simply using encryption makes you look like you have something to hide, because it generally takes quite a bit of work to get an encryption system working. Anything we can do to make encryption more common is good for everyone's security.
Buyers will be interested to hear that the new external Hard Drive XS 3.0 doesn't cost the earth at £99 (approx $160) for a 1TB drive, even though that excludes the £22.99 for a desktop PCI-bus controller necessary to make it work at its intended throughput. Laptop users can pair it with a £25.99 plug-in PC Card to achieve the same effect.
Lucassen also put his finger on another application that should be boosted by the arrival of USB 3.0, namely transparent encryption. "The Hard Drive XS 3.0 also outperforms the competition in terms of security. Our USB 3.0 solution will have high-speed hardware encryption with AES 256 bit - this is not only the fastest but also the safest storage solution on the market," he said.
