Hey guys,
It's my first attempt OC'ing, and after reading alot of guides, i'm still not sure on what's the best way to start this.
My specs: E6850 @ 3.0 ghz (9X333) @ 1.33125v
P5N-E SLI (NB @ 1.208v)
Patriot 2X1 gb ddr2-800 (4-4-4-12 2t @ 2.085v @ 800 mhz)
The ram is unlinked with a 6:5 ratio right now
Evga 8800 GTS 320 mb (stock)
Custom water cooling (apogee, ek gpu wb, swiftech triple rad, dcc+ with modified top, ek nb wb)
Temps (in celcius) : Core Temp: 25/32 (idle/orthos load)
Real Temp: 31/42
Hardware Monitor: 37/47
SpeedFan: 23/32
Ambient: around 23
My goal is to get a pretty high overclock since I have this cooling capacity. (while keeping the voltages low enough so my system doesn't degrade over time, and my temps low)
The voltages you see are set on manual, and are orthos stable for hours.
Basically, I need to know what to change first. I tried to go for a 350 FSB at the beginning (9X350=3150 mhz) but it failed the orthos test after 1 min.
Are there some ratios I have to respect when increasing the fsb? Should I lower the multi first, or the ram? I heard that some fsb numbers will fail the stability test, but that some higher numbers will pass it, is it true?
Thanks in advance.
Real Temp: 31/42
SpeedFan: 23/32
Ambient: around 23
Thanks in advance.
