cooltown831
- Oct 30, 2007
Basically everything defaulted to auto on my motherboard. I heard this is bad/unacceptable for overclocking. Also the CPU fan doesn't spin when my cpu currently idles. The idle temp seems to be anywhere between 25 - 27 degrees celcius according to Speedfan.
I'd just like to feel things out a bit before going [H]ard into this OC. So I guess a modest 2.6 or 2.8ghz for my E2160 would be cool for starters, testing stability, etc.
My hardware is:
Gigabyte GA-P35-DS3R
Intel E2160 L2 stepping cooled with Ultra 120 extreme & Scythe S-Flex E
GSkill 2 x 2gb PC2-6400 4-4-4-12
Radeon X1600 Pro (my 8800GT shows up in 5 days, shutup!
Antec P182 Case
So a few questions...
What kind of temperatures are pushing the limits of this particular chip? I've seen numbers for many other intel chips, are they all generally the same maximums? I searched this forum but there hasn't been much about the E2160. Load/idle temps would help a lot to know for when I test for stability.
Should I be adjusting anything with my memory for a simple OC to 2.8? I'm not sure my memory is set to the timings advertised on the specs of it. If it is set to 5-5-5 whatever, should I change it back to 4-4-4-12?
CPU Enhanced Halt (C1E) - Disabled or Enabled? (Enabled by default -- according to manual sounds like it down volts when it feels like it...could be anti-OC, I dont know)
CPU EIST Function - Disabled or Enabled? (Enabled by default)
Should my CPU fan not be spinning always/no matter what? Seems like right now it often doesn't spin at all when my CPU is idling.
What should I be setting my PCI Express Frequency to? I've heard auto makes it so it raises when I increase my FSB.
Anything else a first time OC'er should know? I've spend at least 20 hours reading up on the whole thing, but if anyone have any insight on my specific CPU/motherboard that might be rare, that would help a ton.
Much thanks!
My hardware is:
Antec P182 Case
Much thanks!
