First time WC, I'm so excited! :D
itsJokko
OKay so I have been doing some research and I came to the conclusion that my my first custom water cooled case will be either Silverstone TJ08-E or Silversone Raven RV02-E. I will be cooling the new ivy bridge i7 and a single gtx680.
If I choose to go with the small TJ08, I'm a little afraid of the temps. I found out that u can easily fit a 180mm Magicool Extreme Rad at the front and a 120mm Rad at the back. The motherboard for this choice will be the Asus Maximus V Gene and a red/black/white theme. Sleeved ofc and with a custom window on the side. How do you think the temperatures will be in the TJ08?
And if I choose the Raven i think you can fit a 560mm Black Ice SR1 Rad at the bottom, atleast I have seen many Fortress2 cases with the SR1. If anyone can confirm this that would be great! And i will also put a 120mm rad in the top of the Raven. The motherboard choice here will be the Gigabyte Sniper 3 and a black/green theme, with UV lightning. So Raven OR TJ08?
Off topic questions:
Do you guys know if Asus will release a Z77 ROG motherboard that is not just m-ATX?
I'm also buying a new screen, the Samsung: S27A750D OR S27A950D, it's the exact same screen just different design, which one do you prefer?
Last one, I also need a new SSD with 200-300GB, which one is best atm? I have been looking at the Intel 520
Thanks sooooooo much for answers!!! :D
I like both of your ideas, so i'm not going to pick sides for that just yet. Personally tho, i'd pic Asus Rog boards for both situations, i just like the feature package they come with.
As for the z77 ROG, the formula has pics out here:http://limages.vr-zone.net/body/15135/maximus_v_formula_1.jpg.jpeg.
For the screen, i'd take the 750D just for the sake that its cheaper. A GTX680 has a displayport, so you dont have to worry about HDMI hz limitations :D
And for SSD, the most reliable are always intel. There are others out there that are faster, but intel is the go-to for long term durability.
The Maximus V Formula is an ATX board... and it has built in barbs for watercooling the mosfets.
You can stick a 3x180mm radiator into the Raven with some modding.
