First time WC build
paradoxum
Ok, this is everything I have, could someone tell me if i'm doing it right.
CPU
Watercool HEATKILLER CPU Water Block Rev 3.0 Socket 775
LGA 775 Heatkiller M4 Motherboard Back Plate
Pump/Reservoir
XSPC Dual 750 Bay Pump Reservoir Rev2 Multi Fascia
GPU
DD-4870 Water Block (ATI HD4870 GPU waterblock)
Radiator
2x Black Ice SR-1 120 Radiator (1x in rear of case, other in top of case connecting to 140mm fan via "Bitspower BP-FA140120-BK 140mm -120mm Fan Adapter - Black" (will this work?))
Tubing
1/2" ID - 3/4" OD XSPC Green/UV Green Hose
Fittings
1/4" Thread Compression Fitting for 1/2" ID - 3/4" OD Tubing : Silver
1/2" to 3/4" 45 Degree Rotary Compression Fitting
Misc
Arctic Silver 5 - 12g
2x Thermochill EC6 Non Conductive Coolant - UV Neon Green
Hose Cutter - Large (10 - 40mm Max)
Small Neck Funnel
My main concern is whether or not I have chosen the correct tube and fitting sizes, will everything here fit together nicely or have I done something wrong? I would prefer compression fittings cause they look nicer and i'd rather not have to clamp. Also is there anything else I am missing from the loop?
thanks in advance
