Hey, I've just finished fitting my new watercooling kit I bought off a fellow forum member over at overclockers.com.au. So far working a charm. Idles at 31c and loads at 35c with the fan at 7v. Very happy with this
With the fan at 12v I get load temps of around 32-33c depending on the ambient in the room.
Just a quick question tho, the fan came bolted to the radiator and is pulling the air through it rather than pushing. Would it better if it was pushing rather than pulling in regards to temp and noise?
The tubing from the radiator is only temporarily coming in through the side of the case until I drill some holes in the back of the case.
Tell me what you think, and if any improvements can be made.
