- Jun 3, 2003
I'd like to put the system in my signature under water. Though the GTX 480 is quite long in the tooth, so at this point I think it'd be best to upgrade to a 7970 and get a block for that, rather than purchase a block for such an old and power-hungry GPU.
I've chosen a kit with the RX360 radiator - it will fit nicely in the top of my 700D. Drive bays should not be a problem for the res. As far as I can tell everything will fit without problems.
Here are the components I plan to purchase:
Frozen CPU's RX360 kit - includes CPU block, tubing, fittings, radiator, pump, and reservoir.
EK 7970 block
Fittings for the GPU block (same as in the kit)
Distilled water (locally)
Is there anything else I need? Any predicted problems with the configuration? Thanks in advance for all advice and insight you see fit to provide.
EK 7970 block
