morkboy_wonder
- Mar 14, 2007
I have decided to take the plunge and go for a watercooled rig. My current hardware is:
coolermaster cosmos 1000
asus striker II extreme
q6600
2x1GB OCZ 1333 ddr3
2 x 8800GTX
2 x 150GB raptorx
razer ac-1
I was hoping to get blocks for the cpu, gpus and possibly for the hardrives. The mobo comes with the fusion watercooling system however I may opt for third party blocks for the chipset and mosfets in the future. I was aiming to take the q6600 to 3.6GHz and run the gpus at 650 core and memory at 2000. Potential hardware I have picked includes:
D-Tek Fuzion or EK supreme for cpu
EK--FC8800 for the graphics cards
watercool silentstar HD-Dual for the drives
not sure about mobo blocks yet
1 x ThermoChill PA120.3 (is this enough?)
1 x Laing DDC-1T Ultra w/Petras Tech DDCT-01s Top
a reservoir
some yate loons
I was wondering what the consensus is? I am not sure if the PA120.3 would be enough for this especially if I go for third party mobo blocks. Also would that pump be enough for the system if 2 radiators are used. Like I say I am new to watercooling but my idea for the plumbing would be a single loop:
RESERVOIR -> PUMP -> RADIATOR -> CPU BLOCK -> CHIPSET BLOCK -> HD -> GPU -> GPU -> RESERVOIR
Any thoughts? thanks
q6600
2x1GB OCZ 1333 ddr3
2 x 8800GTX
2 x 150GB raptorx
razer ac-1
a reservoir
some yate loons
