Well I've been toying w/ the idea of going water w/ my next system, specs are:
Silverstone TJ07
DFI LP X48-T2RS
Intel E8400
PCP&C 750w Silencer
9800gtx (i think...might skimp and wait for the 9900)
2x2gb G.Skill DDR 1066
I'm pretty much lost w/ how to do this, and also a bit scared to try, should I mess anything up. I'm not sure how/where to mount a radiator in this case (top/bottom...left/right?) or how big the rad (or rads) should be. Basically what I want to know is what some of you would do w/ this setup with a $400ish budget for cooling (which I believe should be PLENTY). So how should i go?
Silverstone TJ07
DFI LP X48-T2RS
Intel E8400
PCP&C 750w Silencer
