After reading some guides, and this board for information, as well as visiting multiple vendor sites, I have the pieces for my proposed circuit.
The reason I'm WCing is to extend the life of this 2 year old beast (which was top of the line when built). I have an AiW card, but I think I've gotten past that hurdle. On top of WCing, I'm looking to overclock, but that'll be figured out after this WC endeavour.
Current Specs:
AMD 3000+ Barton (2.1667GHz, I think)
1GB RAM
120GB HDD
ATI AiW 9800 128
350watt PSU
Asus A7N8X mobo
Soundblaster Audigy Gamer and 56k modem occupy PCI slots (country life has its drawbacks...)
Here are the pieces I have selected for my WC circuit:
GPU Block: Swiftec MCW50B @ $38.95 Direct
CPU Block: Swiftec STORM @ $75.95 Direct
Pump: DD CSP-MAG 12V DC @ $49.99 Direct
Radiator: DD Double Heater Core @ $34.99 Direct
Fans: Any suggestions are appreciated, planning on getting standard newegg ones
Shroud: Cardboard and duct-tape are fine I read
Tubing: Clearflex 10ft ~$10
Misc clamps and that blue anti-freeze I saw in another post
Questions:
1. Since I'm overclocking, and I can get the parts in either size, should I go with the 1/2" tubing over the 3/8"?
2. I'd like to simplify and save money by using a T-Line. Would anyone have any valid reasons to go reservoir?
3. I have a mid-tower case, and I understand that I probably won't be getting everything inside of it. What is the recommended placement for the heater core I'll be purchasing?
4. Should I buy RAM sinks for my AiW, since the GPU block doesn't cover both?
5. Anything else I should be aware of?
I've photoshopped a picture I took of the inside of my case, adding a proposed layout. I've included the edit and the untouched.
I'd have flow going from pump > CPU > GPU > Radiator > pump. Would that be an optimal layout for OCing both GPU and CPU?
Thanks for your time and your help!
Current Specs:
1GB RAM
120GB HDD
ATI AiW 9800 128
350watt PSU
Asus A7N8X mobo
Questions:
