[/IMG]
New (old) water cooled comp
3 years later still buying stuff for this thing
Pics make it look pretty messy, i spent a good 30 minutes doing wire management and it looks better in person
XP Pro
Cm Stacker dont know model number(big mofo)
Asus A7n8X-Dlx motherboard
Xp2500+ barton Oc'd to 2.2ghz Xp3200+ specs
1gb pc3200 corsiar xms
Ati radeon X800 pro (agp) not oc'd
pioneer 111d dvd dl buner
Cooler master 550watt PSU
Syba Sy-via-150 Pci Sata controler(not raid)
80gb WD 7200rpm 8mb cache (ide)
250gb WD (sata3.0 running 1.5)
300gb WD (sata3.0 running 1.5)
external 200gb seagate for backup
external 40gb for mp3s for the 360 so i dont have to stream/have computer on
Rear mounted Radbox H20 120 premium water cooling kit
"custom bent" apoge Block cause some capasitors were in the way.
custom cut top of case for triple 120mm fangrill (aquacomputer)
roomate who cut it screwed up and sold me the case cheap
3 "stock" cooler master 120mm fans on top
2 Panaflow 120mm fans in the back
1 ?120mm fan on the rad
3 junk/left over from other cases 80mm fans in front
probably over kill for the fans but its still not nearly as loud as my old
Slk-900 with TT Smartfan @ 5000Rpm altho the temps are about the same 31-34C as they are now..oh well
Laptop with screen chopped off(not by choice) works like a champ
trashed the factory toshiba xp home install put vista on...disaster..forget that
Just installed Ubuntu and beryl for fun, first time using linux, i like it
Toshiba satellite M35-S320
Centrino 1.5ghz
512mb ram
Nvidia Go5200 Fx (runs trackmania and css great)have not messed with it on ubuntu yet
60gb hd
G15 keybord/G5 mouse
Bose triport(talk all the trash you want about them they sound good to me)
wal-mart Bananna Rack for headphones
zalman "5.1" headphones, dont use anymore bose sound better
Creative Sound Blaster external usb 24bit works for me
21" Wide Gateway Fpd2185W
19" wide Gateway Fpd1975W
i can do dual screens on the tower or 1 screen for each computer or picture in picture w/ the 360 on the 21 inch or just have the ubuntu on the 21" with the tower in picture in picture..
you get the idea its pretty versitille , i should get a kvm switch, for now i just use a female vga adaptor
And i still dont own a digital camera, using 1.3mp camera on Lg Cu-500
