endorphins
- Aug 19, 2006
Ok, so I've made a post earlier about looking for a good water cooling system. I've finally got my paycheck have a little over $300 all together to spend on a water cooling system, and I want to make something that will really lower the temp on my computer. I play Counter Strike Source, WoW, and Lineage 2 on my days off anywhere from 4-8hrs at a time. What exactly will I need? What should I look for? Where should I look for it? Will my pc be completely fanless? And my last question, Is it hard to install a water cooling system when you or nobody else you know has ever done it before?
My system specs are:
Raidmax RX-9 Case
P5N32-SLI Delxue Mobo
Intel Extreme Edition 3.46ghz Pent4
2GB of RAM
Nvidia 7900GTX 512MB gfx card
Sound Blaster Audigy SE
I am a little hesitant to actually install a water cooling system, only because I've never done this before. From what I have read though, if I do get the right set up it may drastically change my temps and everything. Anyway, thanks for all help in advance.
Raidmax RX-9 Case
2GB of RAM
