Little_4nic8er
- Oct 24, 2009
Hello everyone.
I have played with my FSB in a very mild manner in the past with varying chips but never went as far as to get a 3rd party cooler, or up the voltages at all. I managed to get a great deal on a Q9550, (C1 revision unfortunately.) and replaced my E6850. I noticed the 9550 runs a lot warmer than my 6850 did, on both load and idle. The 6850 would idle at 24C, the 9550 40C. The 6850 would hit 40C, and the 9550 60C on load at default clocks. I used AC MX-2. I also reapplied it twice to make sure it wasn't a compound issue. I bought a Noctua NH-U12P SE2 (and a 5870) and received the cooler yesterday. (The GPU was back ordered before my payment went through. Tis a popular card. Sold out in less than 2 days.)
After spending a good part of the day completely dismantling my PC I now have it all up and running. (My cables are much neater than before to, though they were not terrible.) It dropped my temps quite nicely.
I have started to OC, and have the 9550 at 3.63Ghz. It was Prime95 stable at less voltage, but I like to push things so I ran a 5 pass Intelburn test. It failed shortly after the second test would start. So I pushed all voltages up. (Incrementally.) They are now as such. The vcore is set to 1.375000. FSB OverVoltage +0.3, DDR2/DDR3 OverVoltage +0.3, and MCH OverVotlage +0.2.
My temps hit 68C max with an Ambient of 34C (Core0, the rest were up to 5C cooler during fluctuations.) during a "Very High" Intelburn test scan, but I passed the test with no BSOD. (I've seen so many over the last 48 hours.)
It (Core0, always the hottest.) is currently idling at 44C with an ambient of 35C. (core1-3 vary between 37-40C.)
So what I am wondering is does anything here set off alarm bells for those of you who have done this for some time? Did I need to tweak the DDR /FSB/etc overvoltages so high? I kinda just bumped them up here and there when just a vcore bump didn't work. Is trial and error the only way to find the weak spot, or is there something that can help point me to a specific area?
I know I'll never get close to pushing it with normal use. (Gaming.) So should I be safe? Should I maybe aim for just Prime95 stable, at less voltages?
Other relevant components:
Gigabyte P35C-DS3R (Rev. 1.1)
6GB DDR2 800Mhz OCZ Reaper @ 5-6-6-20 (1:1)
Antec 900
Antec Truepower 650W
Apologies for the short novel but I'm hoping I covered what needed covering. If I didn't, please feel free to ask for whatever I may have missed.
Thanks.
edit: Added and corrected info.
Antec 900
Thanks.
