Just finished installing my second evga 780TI sc driving 3 vg248qe in portrait.
All I did was turn the machine off, stick the other card in with the sli bridge and reboot. Tada, it works. However all three monitors are being driven by my original card. Is there any reason to drive other monitors off the other card? Or are all 3 ok on one card?
Seems to be fine, just curious if there is something I am missing. The nvidia sight seems not to suggest my current setup ( 1 display port, 2 dvi ).... but it sure as hell seems to work.
First benches as such....
Haven 4.0, high quality, normal tessellation, aa x2...
with one 780ti sc in factory config scores 983, 39 fps average. This is at 3240x1920.
both cards at stock clocks, scores 1713, 68 fps average.
Sure seems to be functioning to me.
I do seem to be noticing some slight hitching during the benches... wasnt there with one card. Is the the microstutter I keep hearing about?
Any other info for a first time sli'er would be great....
Last time I ran 2 cards was 3dfx era.....
