First time seeing this
Sparky
[10:18:14] Project: 3300 (Run 1911, Clone 0, Gen 0)
[10:18:14]
[10:18:14] Assembly optimizations on if available.
[10:18:14] Entering M.D.
[10:18:21] Protein: p3300_riblig
[10:18:21]
[10:18:21] Writing local files
[10:18:21] Extra SSE2 boost OK.
[10:18:21] Completed 0 out of 250000 steps (0)
[10:19:08] Quit 101 - Fatal error: Box exploding.
[10:19:08]
[10:19:08] Simulation instability has been encountered. The run has entered a
[10:19:08] state from which no further progress can be made.
[10:19:08] This may be the correct result of the simulation, however if you
[10:19:08] often see other project units terminating early like this
[10:19:08] too, you may wish to check the stability of your computer (issues
[10:19:08] such as high temperature, overclocking, etc.).
[10:19:08] Going to send back what have done.
[10:19:08] logfile size: 8978
[10:19:08] - Writing 9531 bytes of core data to disk...
[10:19:08] ... Done.
[10:19:08]
[10:19:08] Folding@home Core Shutdown: EARLY_UNIT_END
[10:19:10] CoreStatus = 72 (114)
[10:19:10] Sending work to server
[10:19:10] + Attempting to send results
[10:19:10] + Could not connect to Work Server (results)
[10:19:10] (171.64.122.127:8080)
This borg is all stock with P4, 3.0Ghz, 512mb ram and has never had a problem. I think the server exploded as it cant connect since the 8th.
marty9876 said:
I've seen it before.
Bwahahahahaha.
See if you can connect to that server: http://171.64.122.127
Should just give you a page that says OK if you can get to it.
Oops, guess I shoulda read your whole post, Couldn't tell you why the WU died so fast. Looks like a pretty new unit, might still have problems with them.
