Darth Bobo
- Jan 6, 2007
I just thought that I would write a bit about my first experience with overclocking an E6600 or anything for that matter. My system is the one in my sig and I can tell you now, it didn't blow up (YAY!)...
So I decided that I wanted a new computer a while ago and started looking for the money to make that happen, apparently the "you're a student -forget it!" sentiment wasn't true this time around and last friday (Feb. 16th) around 40 kgs of computer hardware arrived on my doorstep.
After a bit of Dremeling into the motherboard tray of the Antec P180 (never used a Dremel before either -beginning to see a pattern here) I got the system assembled and to my pleasing it actually posted the very first time I powered it up. This was another happymoment for me, as the first POST means I didn't forget anything. Into the DVD drive goes Vista 32bit, a half hour later I was running Vista. So now I had a fully functional PC running at stock speeds, that's pretty damn fast compared to what I was used to (P4 2,4GHz, ATI9600, 512MB SDRAM), still not what I wanted.
So I read all the advice I could find on OC'ing the Core 2 Duos and got started, disabled a bunch of stuff that I read I should disable and set my FSB:RAM ratio to 1:1. Then I set my vCore to 1.3V, the FSB to 333, all other Voltages to "Auto", rebooted and crossed my fingers. Guess what it started and it tested stable with OTTC YES! My first overclock.
Yesterday I was looking at PC Probe II and getting a little perplexed as I kept getting warnings about too high NB voltage and FSB termination voltage, so today I decided to force them to stock! Guess what, it worked and was stable.
After my last endavour I got brave, so I entered the BIOS once again and upped my FSB to 367MHz (vCore =1.3 : NB volt = 1.25 : FSB termination voltage = 1.25V : all other on "auto"), saved and rebooted, and guess what, it didn't make it into Windows
I guess I need a little more vCore, NB and FSB voltage for that...
I'm currently running my E6600 at 3GHz@333FSB, vCore at 1.3V, NB voltage and FSB termination voltage at 1.25V, memory at 4-4-4-12@667MHz and 2.1V. I'm idling at around 36C which I think is a little high, still waiting for the AS5 to cure, and loading at 52C (Temps are from TAT).
If you read this far I salute you and want to say thanks to the people who was kind enough to ever reply to any question, not just mine, about OCing -especially the C2Ds here on these board, you have helped me a lot and for that I'm grateful! Thanks!
I'll probably try to shoot for 3.3GHz in the near future, but for now I'll enjoy my modest 25% OC a bit and play some games!
