First time overclocking need some advise from the pros
ezland00
Hello all,
Here is what i have:
AMD 3400+ Venice 2.2ghz, with freezer pro 64
Asus A8N-E, v1013 (latest bio)
CORSAIR ValueSelect 1GB DDR400
BFG GT6600 128mb
Creative Audigy 2 ZS
WD 120gb IDE
I might be ask stupid question, but to me they might not be. Please don't laugh at me.
here we go with the questions:
1. what's the normal idel and loaded tempeture?
2. Do i need to set the voltage when i overclock?
3. Does overclock affect memory and vidoe card?
4. What's the main thing i need to look out for when overclock
I loaded Aibooster from Asus CD. Should i use this to overclock or change the settings in the bios?
thank you
Firstly no one would laugh at your questions.
1.average temps depend onyour setup cpu cooling etc.
2.voltage changing is optional i dont do it myself.
3.changing fsb will effect ramspeed not sure about video card but possibly.
4.main thing you need to look out for is temperature.
I just use the AiBooster and was able to overclock to 2.44ghz stable. When i reaches 2.5gh loaded, couple min. into the game. my computer show up a blue screen. when i reboot the computer, it say the CPU fan is not working, but it is. i slower the frequency and checked the temp. its around 40c when this happen. i have the Qfan enable, is this the problem?
the voltage on Aibooster alway shows between 1.39v - 1.41v.
temp. 34c idel, and 41c loaded
again thank you all for helping out
EZ
Few corrections
1. Keep it below 55C at load (gaming, benchmarking, anything that bumps the CPU usage to 100%), this is true for every AMD CPU (not sure about Intel), anything above that and you're risking your CPU health. The maximum max should be 65C
2. Usually it is a must if you want a good overclock, you won't get too far without it unless you are lucky with a good chip. Since higher volts=higher OC.
3. Changing FSB does change the RAM speed but not the video card speed, though it can also affect your hard drives unless you have a lock on their speed (which usually every new mobo has it by default)
4. I neglect the temperature, I never had any problems with mine, but that is definatly not the right way for anyone else. So temperature. And remember, find the best speed combination, find the highest FSB of your CPU and highest MHz and go from there, DO NOT shape your CPU speed based on the RAM Speed. CPU speed>RAM speed when it comes to performance
Yeah true I was just telling him that voltage is optional as a person that is new to overcocking I wouldnt want him to fry his chip with to much voltage the reason i dont change voltage is locked bios.
Just don't go over 1.55vcore. As for your puter blue screening, that could've been caused by heat. Even though you saw it registering 40c, by the time you were able to read the temp it coul've cooled down quite a bit. Remember, when booting up it isn't under much of a load.
Also, temps are dependant on your cooling/overclock/voltage/airflow. Typical idle temps are roughly in the 30c range and load temps can be between the 40-50c range. I idle at 28-30c and load at 43-46c with 1.55vcore and a 600mhz overclock.
Actually the most processing a CPU does is at loading Windows and gaming... it has to load and calculate all the neccessary files, hence heating up the most
EZ
Great, not bad for a quick go.
I use the same motherboard and found that Aibooster doesnt always behave.
While overclocking, it increases the speeds of things it says are staying the same, even if they are 'locked' in the BIOS.
I recommend using clockgen to find the best clocks and then set them in the BIOS.
If you want to find the max your CPU can do, set your memory to a slower speed in the BIOS first.
Once you have your max cpu speed, you can play with memory speed settings to find the optimal.
Where you are now, its possible
1) your PCI express bus is being clocked and you hit a stability limit. Use clockgen to set individual bus speeds.
2) your ram has maxed out, slow it down and test again.
3) you need more voltage to the cpu. Some good advice was given earlier on this.
4) your HTT speed might be too high. Set the HT multiplier a bit lower
Your temps are great so you have a fair way to go.
Here's something to bear in mind when oc'ing this board: to get the BIOS oc settings to set in the XP environment, you MUST have the floppy controller enabled in the BIOS, even if you don't have a floppy installed! You can disable the controller in the XP device manager if you like later. I found this out the hard way, thankfully I stumbled across the answer. I know it sounds bizarre, but it works.
