Just did my first overclock today on my Q6600, running 9x333 and currently doing Prime95. I was using the overclocking guide that's stickied and it said to run Prime95 for >24 hours to make sure the CPU is stable the the settings. Well I also left my voltages on "Auto" since it was my first time doing this. Now I was wondering, do I need to do Prime95 before I start dropping them? Coretemp gives VID at 1.3250, CPU-Z gives core voltage at 1.392 idle and dropped to 1.352 (drops sometimes to 1.344 and goes back up) after I started running Prime95.
I would also like to know how this sounds so far: temps before running the test were 35-35-28-28 idle and now they're at 56-54-49-49 load. I'm using an Arctic Freezer 7 Pro ( I know its no Xigmatek S1283, but I got it real cheap ) on a ASUS P5Q in a Coolermaster 690 vanilla.
Any tips/comments/suggestions would be greatly appreciated!
PS If a different HS/fan would make a difference in my temps, IE Xigmatek S1283, I will consider picking one up.
