First time over clocking
I am new at this gaming thing. I am an older man 56 and am NOT hip to what up. But I want my computer to be the best it can be safely and need help. I put this computer together.
For some reason it is not displayed that I have two GeForce 8800 GT cards linked in the SLI dual mode.
When I open the NVMonitor in the Bus speeds section the MCP PCI-E its box is red and the setting is 2500.000MHz.
In the Voltages section the memory box is yellow, the HT(SPP-MCP): is 1.2000v, and the nForce box is red with 1.5000v.
I have changed nothing since I put this computer together and don't understand what I'm viewing, why the settings are what they are. I am looking for some help setting this unit up . This is all the specs I could locate describing what inside the computer. I also have 4 single matched memory cards inside not the 2 listed. There is 1 HD, the main one, is 759 GBs and another 200 GBs HD. Each has a cooling fan, the memory chips have fans, The CPU has a Thermmaltake 8 copper tube with alum. cooling fins and its own fan. I installed 2 120mm case fans up front, 2 80mm fans in the back and added a 80mm on the side directly above the CUP cooling tower and the power supply is a Ultra / X-Finity / 600-Watt / ATX / Dual 80mm Fan / SATA-Ready / SLI Ready / Black / Power Supply. Big 22" flat LCD monitor, HUBU gaming mouse yadda yadda. The only reason I mentioned all this stuff is to ask if this is to some responses on how well it should handle some over clocking to increase the over all performance of the computer in all sectors. Either gaming, or doing my PhotoShop and Dreamweaver classes, really anything I want it to do.
OS Name Microsoft® Windows Vista™ Home Premium
Version 6.0.6001 Service Pack 1 Build 6001
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name MARTINHAYES-PC
System Manufacturer NVIDIA
System Model NFORCE 680i LT SLI
System Type X86-based PC
Processor Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz, 2400 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date Phoenix Technologies, LTD 6.00 PG, 7/11/2007
SMBIOS Version 2.4
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.0.6001.18000"
Time Zone Pacific Standard Time
Installed Physical Memory (RAM) 4.00 GB
Total Physical Memory 2.00 GB
Available Physical Memory 913 MB
Total Virtual Memory 4.23 GB
Available Virtual Memory 3.18 GB
Page File Space 2.29 GB
Page File C:\pagefile.sys
This is the current system info:NVIDIA System Information report created on: 01/23/2009 20:34:47
System name:
[Display]
Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (2400 MHz)
Operating System: Windows Vista (TM) Home Premium, 32-bit (Service Pack 1)
DirectX version: 10.0
GPU processor: GeForce 8800 GT
Driver version: 181.20
Stream processors: 112
Core clock: 640 MHz
Shader clock: 1600 MHz
Memory clock: 950 MHz (1900 MHz data rate)
Memory interface: 256-bit
Total available graphics memory: 1279 MB
Dedicated video memory: 512 MB
System video memory: 0 MB
Shared system memory: 767 MB
Video BIOS version: 62.92.16.00.86
IRQ: 16
Bus: PCI Express x16
Core clock: 600 MHz
Shader clock: 1500 MHz
Memory clock: 900 MHz (1800 MHz data rate)
Video BIOS version: 62.92.16.00.09
IRQ: 16
[Components]
nvCplUIR.dll 1.5.700.70 NVIDIA Control Panel
nvCpl.cpl 2.2.350.00 NVIDIA Control Panel Applet
nvExpBar.dll 1.5.2400.14 NVIDIA Control Panel
nvCplUI.exe 2.2.350.00 NVIDIA Control Panel
nvViTvS.dll 7.15.11.8120 NVIDIA Video and TV Server
NVMCTRAY.DLL 7.15.11.8120 NVIDIA Media Center Library
nvDispS.dll 7.15.11.8120 NVIDIA Display Server
NVCPL.DLL 7.15.11.8120 NVIDIA Compatible Windows Vista Display driver, Version 181.20
PhysX 8.10.13 NVIDIA PhysX
nvGameS.dll 7.15.11.8120 NVIDIA 3D Settings Server
The 680i boards are notorious for not being good at overclocking (or anything else IMO), so if you want to play with overclocking then a motherboard upgrade is what you need.
