Shadowprice
- Jun 7, 2005
Hello, first post in this sub forum here. I want to OC my Phenom II setup a little bit, as I've been nagging back and forth at myself of wanting to upgrade to a SB build but part of me wants to see if I can OC to get some more performance on my processor and carry out my build longer, the end result, saving some money.
Now, this is my first time ever overclocking a processor, I've always ran stock speeds. I've looked up some guides online and some YouTube videos, but so far, my OC attempts using AMD OverDrive have been very unsuccessful, I haven't tweaked the voltage, but even so much trying to increase the multiplier to 3.6ghz and running a stability test, my temps get above 50c, if I increase the multiplayer to 3.8ghz, I get a blue screen instantly.
For the record, here are my complete system specs.
Processor: AMD Phenom II X4 955 Black Edition 3.2Ghz
Power Supply: Corsair CMPSU-650TX 650-Watt TX Series 80 Plus
Motherboard: ASUS M4A87TD/USB3
GPU: AMD Radeon HD 5770 1GB
RAM: Corsair Vengeance 8 GB ( 2 x 4 GB ) DDR3 1600 MHz
Case: Antec 300 with default fans and no mods
HD: Seagate Barracuda 7200RPM 500GB
I'm using a aftermarket CM Hyper 212+ and Artic Silver 5 thermal paste for cooling.
Games I mainly play are Skyrim, WoW, and some BF3 (mostly SP) .. I'd like to see if I can squeeze a bit more performance out of my rig, as I am almost there in my own terms of satisfaction, and without having to upgrade my rig. Although, I'll probably be getting a GPU upgrade in the few coming weeks here.
Can anyone help me with some OCing? Not looking at anything extreme, but I've heard even so much of 3.8ghz on air is very obtainable.
