Santasballz
- Jan 10, 2005
I've decided to go all danger den:
cpu block:
The Danger Den MAZE4 for A64 and Opteron Motherboards
http://www.dangerdenstore.com/product.php?productid=31&cat=58&page=1
gpu block:
The Danger Den Acetal MAZE4 GPU
http://www.dangerdenstore.com/product.php?productid=150&cat=48&page=1
pump:
The Danger Den DD12V-D4
http://www.dangerdenstore.com/product.php?productid=36&cat=4&page=1
reseervoir:
Danger Den Bay Reservoir High-Density Polyethylene
http://www.dangerdenstore.com/product.php?productid=51&cat=27&page=1
rad:
Black Ice Xtreme Radiator
http://www.dangerdenstore.com/product.php?productid=1&cat=13&page=1
tube:
Tygon 3603 Tubing
http://www.dangerdenstore.com/product.php?productid=61&cat=33&page=1
or
http://www.dangerdenstore.com/product.php?productid=58&cat=33&page=1
clamps:
Plastic Snap Tubing Clamps
http://www.dangerdenstore.com/product.php?productid=62&cat=33&page=1
water addictive:
i have no idea...question about it below.
THREE IMPORTANT questions:
1) if i want to water cool an AMD 64 3500+ and a nividia 6800 gt, is one black ice extreme radiator enough? or do i need 2?
2) clearflex or tygon tubing? does it really make much of a difference?
3) wat water additive? i am a little confused on this one. seems like some u have to mix with distilled water, while others u just pour directly in...what's up with that?
everything looks ok?
edit: 1/2 tubing or 3/8? they seem to cost the same amout of money... (i've always thought 1/2 cost more cause its thicker)...but which one?
cpu block:
gpu block:
pump:
reseervoir:
rad:
tube:
Tygon 3603 Tubing
or
clamps:
water addictive:
