newls1
- Sep 8, 2003
As the title says, I find this socket either REALLY easy, or I did something wrong? In the installation instructions it says "align the pins with the CPU, and make sure the pins fit into there corresponding holes." Well, I know the CPU is matched right, but there are NO holes on the bottom of my C2D E6300, just gold colored surfaces. Am I right in thinking that the pins on the socket area just touch the bottom of the CPU? If so, then its installed correctly. Thats what I did, then i pulled back the lever, and nice and tight it went. Please tell me I didnt do something wrong.
