first time dremeler (pics)
lemons
just got a dremel, so hacking away at my PC-86 (i think that's the model, had it for a few years)
120mm fan in the front. Not the neatest job ever, but hopefully a little more work and it will look ok. Gonna try to fit the same size fan in the back next. gulp
and one in the back
not really recommended as the fan needs to be removed before you can pull out the motherboard tray. I guess it also weakens the structure of the case. i'm happy with it though.
looks nice, but a lot of [H]ard work
think I'll just get the new PC-7 Plus which already has 120mm fans in the front and rear
great job, especially for a first time dremel user
have any pics with the front back on?
You'll want to cover those holes under your rear fan or it'll just suck a bunch of air from outside instead of pulling out all the hot case air.
is that true? I'll have to check it out with smoke from a cigarette or something when i eventually get the side pannels back on. thx for the tip.
