Hi there, right now im putting together a brand new computer, and im going to cry.
I have had so many problems.
I have a tyan tiger k8w and a lian li PC75 and after i have almost everything in the case, i find out they are not fully compadible.
The pin layout for the motherboard does not match the pin layout of their front cables.. (hdd light, speaker, power switch... etc).
It turns out the mobo requires a two pin power led, but the lian li is a 3 pin plastic thing with only two wires.... OMG
I was just wondering, which is the screwed up one.. the lian li? or the tyan mobo?
On a side note, the lian li came with no instructions whatsoever, and on the box it says pentium 4.......... im not sure if they made a "amd64" model... but i do know that they have no help on their website.
I would hate to have to take everything out of the case now just for a power led light not being compadible.
~Thanks
~Thanks
