I was wondering, I got 2 case fans with my comp, they both have what appear to be 2 power connectors on them. Do I connect the fans together and plug each on into the PS? This would make sense if I had a fan controller?
Yes you can. You want to check the amperage and make sure you're not overloading the rail whenever you're daisy chaining fans. With just two fans though you'll be ok.
Make sure you check the amperage on them then. I tried daisy chaining 4 120mm fans on one molex connector and it wouldn't work. The fans just kinda 'ticked'. Overloading a rail isn't generally a good thing to do.
