First time building a WC system
ctguy1955
I removed my H100i because I wanted to WC my MB, a M7F, which has the cross chill
availability and I wanted to use it. I was ordering things for three days in a row as
I was not quite sure if I was going to need 90's 45's or what to keep my hose
from making too sharp of a bend. I just ordered another 200mm Rad and fan
for the front of my 650D case and it will be here this Friday.
I was pretty lucky that my entire hard drive tray was able to unbolt
from the bottom and fit right into the three empty slots under the DVD player.
I used a few tyraps to lift up the tray to have more room to get at the top
of the reservoir as I thought I was going to put a 90 degree fitting with
some tubing and an end cap to use for filling, but a syringe and needle does fine.
I used boiled distilled water with a kill coil in my res, and added three drops
of dead water I had to order 6 feet more of tubing as the one hose from my top case
rad will not reach my new ordered Rad for the front. Never hurts to have some extra hose.
So far I have only messed with OC'ing a little bit.
I am now at 4.702 at 1.349 v @39C, but when I had my H100i setup, I had 4.746 @1.298V 55C
Sure messed around with my settings and dont remember what I did.
Being 59 can do that to ya !!! LOL
I added a fan for the memory and hope that helps cool em down. Im not OC'ing them.
I hope that mounting the new 200mm rad wont be too bad, Ive seen other 650 cases
with them so I know the rad fits, I just dont know how to bolt it to the bottom of the case.
Im looking forward to getting my new 200mm Rad and Fan tomorrow and
seeing if my temps go down.
I installed my new 200mm rad and fan yesterday, but have to wait until next wednesday to
get my other fan and adapter plate for my 200mm rad push/pull config.
